Home > Puma (Tdci) > PAS Fault |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4504 |
Mine was losing PAS fluid but I could not find the leak. The mystery was solved when I traced the drips up along the piping to a lose nut attaching the pipe to the bottom of the PAS reservoir. Once I tightened this the leaks stopped. Had it checked by a main dealer when it was in and they said my repair was sound. Seems a lot were not fully tightened on assembly. If it leaks again just check the pipes from the reservoir- and carry some PAS fluid with you. 1982 88" 2.25 diesel
19th Feb 2009 8:26pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5024 |
Thanks - did have a look along the pipe top - not to say it wasnt, but i couldnt see it.
It did seem further along and sprayed back - almost around the pump area. Again not sure will see what they say when i get it back and hope they fixed it (but will check your fix anyway) Mike |
19th Feb 2009 8:52pm |
Only way to check this is to lie on the ground underneath and look up. Any fluid on the outside of the pipe will be easily seen. It gathers where the pipe straightens out and collects in a series of drips. You will be able to see it easily enough. In the first instance pull the bonnet and prop it open, this gives more light underneath. The nuts are easily checked with your fingers with the bonnet open and any fluid will be felt. 1982 88" 2.25 diesel
19th Feb 2009 10:24pm |
Thanks Will do Mike |
19th Feb 2009 11:37pm |
havent had chance to check, but the dealer said it was the gasket, new one in and we were away on holiday - im going to try and fin d 5 minutes to check leaks and levels tomorrow, just glad they fixed it and in only 6 hours! Mike
21st Feb 2009 8:08pm |
Joys of Joys
Pump has been failing car was looked at monday - booked in today; a fight with lr to get a car lr assist then stepped in and sorted it. today - no part at dealer; hopefully tomorrow...hire car is at least sorted - although they are struggling to find a lr for me.... tomorrow Mike |
24th Feb 2009 10:21pm |
