Home > Maintenance & Modifications > Patriot Security Tilt/Cage Fitted to my DC |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 |
Do they have that kit in black ? It's on my wishlist for Santa ! Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
22nd Nov 2011 3:26pm |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 652 |
Hammerite make a black version....
22nd Nov 2011 3:33pm |
MuddyMarky Member Since: 01 Feb 2010 Location: Oxfordshire Posts: 548 |
They powder coat it black. I think he said approx £50 (?) and it takes a few days extra. Best thing is to give them a ring Mark
2011 110 XS DC Stornoway Grey |
22nd Nov 2011 3:34pm |
thanks!
btw ... those gas struts is part of the kit or is diy ? and does it have a lock ? Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. Last edited by lrmaniac on 22nd Nov 2011 3:38pm. Edited 1 time in total |
22nd Nov 2011 3:36pm |
DIY.....Range Rover bonnet strut Mark
22nd Nov 2011 3:37pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
Hi Joao,
The standard finish of the tilt security cage is natural as shown. Yes I am sure Patriot will get it powdered coated for you. Minimum charge for powder coating is £25 + VAT. Alternatively we have several powder coaters close to us so if you wish your tilt security to be shocking pink I am sure that I can arrange it! Current retail price is £674. Not sure what carriage would be to Lisbon however. HTH Brendan |
22nd Nov 2011 3:40pm |
...pink I'll pass !!
It's a great piece of kit, very usefull .... just haven't convinced myself to put a side 800€ to get one ... althoguh I want (and could use a lot) one! Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
22nd Nov 2011 3:58pm |
Just trying to be helpful Joao We sometimes can get slightly different/unusual/one off things done for customers. Brendan PS I am surprised Barbara daughter has not asked for pink rock and tree sliders YET! |
22nd Nov 2011 4:18pm |
Mark_110DCPU Member Since: 26 Jul 2010 Location: West Sussex Posts: 78 |
Blimey - another one! I thought I had the only one...
I have also modified the door to open upwards, but I thought that having exposed rivet heads rather compromised the security aspect of the cage, so the hinge is installed in the same way as the original side opening one... Mine is Black, and is far less obvious as a result - I guess I should take some pictures of it... Cheers Mark [:O|===|O:] 2001 110 TD5 Doublecab |
22nd Nov 2011 4:19pm |
I also re-mounted the hinge/rivets in the same way as it was supplied originally. I assume the bottom line is that if someone is willing to drill out the rivets, then it wouldn't really matter what vehicle/arrangement I had.....ie, they'd get in somehow anyway! Mark
22nd Nov 2011 4:26pm |
Please don't take this the wrong way - I'm genuinely intrigued. Given the cost and the faffing about with the door, why not just fit a hard top of some description? Darren
22nd Nov 2011 5:05pm |
No problem....I had an IW top before this. It wasn't at all water tight. I've managed to get my tilt to be pretty much that now, with a little time and patience. The 'faffing' about with the door took me approx 30 minutes, including the fitting of the gas strut. Also (and probably the biggest thing) I much prefer the look of the canvas tilt on the DC.
It's also able to be locked, and as I said above, I'll be able to also secure the lower tail gate at the same time with a small mod. The cost was £674 delivered, inc VAT, so I appreciate I could get a thin ally hard top (such as another IW/Gamic, etc), but they would also be much easier to get through than the cage above (they are made of much thinner material). I know it perhaps isn't to everyone's taste, but a couple of people showed interest the other day, so thought I'd get a thread going Mark 2011 110 XS DC Stornoway Grey |
22nd Nov 2011 5:18pm |
Hi Mark,
Nothing to do with taste - your truck, your choice - I just wondered if there was some particular benefit to this set-up over a conventional hard top. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
22nd Nov 2011 5:38pm |
Buzz Member Since: 11 Oct 2011 Location: Inverness Posts: 235 |
Hi Mark,
Thanks for posting this as I was interested. Looks great! |
22nd Nov 2011 5:53pm |
