Home > Tdi > 300 started tapping at rear of engine |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 710 |
Should also mention that I can’t feel any blowing coming from either the head, rocker cover or exhaust gaskets, if that helps.
21st Sep 2018 10:33am |
Could be the vacuum pump. ISTR that made a tapping noise when it was failing on a 300tdi Discovery that I owned some years ago. Darren
21st Sep 2018 10:37am |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 490 |
Mine started making chuffing noises and it turns out the head gasket was blowing out of the back of the head. If you put your hand down between the head and bulkhead you could clearly feel air blowing. Might be worth having another look as it sounds exactly like my symptoms Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
21st Sep 2018 3:23pm |
annette Member Since: 24 Nov 2017 Location: Tilarán, Costa Rica Posts: 68 |
wouldn't it be a blown manifold gasket.. he said PASSENGER side but I don't know whether he means left or right by that ( i know the British can be really weird about left or right, the call it OS and all sorts of things)
So if it is a RHD the passenger would be where normally the driver is. in that case it could be what happened to me, there was a stripped thread in the head ended up putting in 10 helicoils and a new gasket, all fine!! Fixing Land Rovers in rural Guanacaste |
21st Sep 2018 4:09pm |
Thanks for the suggestions folks, I’ve also been told it could be a injector seal, I’ll have a good look at it in the daylight in the morning.
21st Sep 2018 9:01pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4940 |
Injector seals make a hissing noise, not sure if that the same with Mechanical pump diesels. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
22nd Sep 2018 2:13pm |
On further investigation, it seems like the head gasket is blowing
I can see a 10mm gap in some dust that’s accumulated at the back of the block where the head sits and it’s blowing from there. Not bad going really, 250k miles and it’s first blown head gasket. |
23rd Sep 2018 6:11pm |
Glad you found it
300tdi head gasket isn't too difficult especially if you have the Haynes manual. I would recommend replacing with the metal gasket rather than a composite one - be sure to replace like for like thickness if you're not getting the head skimmed. Good luck! Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
23rd Sep 2018 6:17pm |
Cheers, hopefully it’ll be fairly straight forward, It’ll be the first time I’ve done a 300 head gasket.
23rd Sep 2018 6:36pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1571 |
Not hard to do one. Just like any head cleaning is important and make sure you clean out the threads in the block and dry them. Little light oil on the threads.
24th Sep 2018 1:18am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10530 |
Good you found it in the end
Your gasket did a bit better than mine, my first gasket went at 232,000 and it was blowing at the back like yours 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
24th Sep 2018 9:45pm |
