Home > Td5 > Spring rates |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2664 |
Check my thread here http://www.defender2.net/forum/topic13312.html
It has the spring rates on Page 2. and here http://www.defender2.net/forum/topic49065.html?highlight=isolator I've done a lot to get "Disco2" quality road manners Changing the shocks to Koni really helped too - mine has a really comfy ride now, especially with 35psi in the back tyres Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
7th Sep 2018 8:42am |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 903 |
Changing to progressive springs like the Puma had helps a lot. Isolating the springs from the frame helps much more to stop a harsh ride.
Use Disco II spring isolators on the top of the front prings and OEM 110 spacers for the rear. If you want really cushy ride install standard isolators to the bottom of the front springs as well. The rears should have the stock isolators already on them (ANR3060) Good luck Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
7th Sep 2018 4:10pm |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2877 |
It’s all in your head the tdci is a quieter car anyway
7th Sep 2018 5:11pm |
Do you have any more details on those OME 110 spring isolators, please? My Google powers are failing me. Darren
7th Sep 2018 5:18pm |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 810 |
Check out here gives you part number and I'm sure you can order from someone closer
https://expeditionexchange.com/shop?olsPage=t%2Fold-man-emu |
7th Sep 2018 6:59pm |
Great, thanks. Darren
7th Sep 2018 8:45pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2264 |
That’s really useful thanks for the replies. I will do as suggested, Puma springs with isolators.
Yes the Puma was also quieter than my TD5! |
8th Sep 2018 10:48am |
Those OME isolators are actually for Toyota Tundra. You can alao find rubber ones which can do the same thing. Glad to help out. I got mine here. (Link saved in £ for you).
Good luck. http://www.lowrangeoffroad.com/catalogsearch/result/?q=OME80PR10 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
8th Sep 2018 3:46pm |
Thanks. Found them at Devon 4x4, but they're £25 for two inc. postage Darren
8th Sep 2018 9:26pm |
