Home > Maintenance & Modifications > Retrim |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7875 |
There are kits available, doesn't seem too hard, but not done myself. Others on here have though, so hopefully comment soon. James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
14th Jun 2018 10:12pm |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2073 |
OEM Developments sell whole seat packages as Factory fit LR Defender seats for great prices.
As cheap as a leather kit and original parts. Worth a look. |
14th Jun 2018 10:26pm |
I did it on an old Frontera once. I've also replaced the drivers seat covers/foams on my Defender.
It's not especially hard, although fiddly in places. Defender ones are quite a bit easier than modern car seats. You'll probably find you need new foams as they fall apart with age when you take the old covers off, and the heaters are glued to the foam. I found the metal hog rings they use are more hassle than they're worth, you're better off just using some small cable ties. They're much easier to fit and remove in future and you don't need the special pliers for them. |
14th Jun 2018 10:42pm |
