Home > Puma (Tdci) > Inner seal rear axle |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 |
Last monday i was repairing/replacing the inner seal of the rear axle.
On the left (with grey ring inside) is the new one. On the right is the old one (without grey ring). So my question is. Should it be installed with the gray ring Or without? Click image to enlarge a defender from 1984 pretending to be a puma with a touch of Range Rover |
31st May 2018 11:39am |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1570 |
Might help if you say what year/axle the car is/has and what part number the seal is?
31st May 2018 2:50pm |
Defender 110 (Tdci) from 2008.
The part nr is: FTC4785G inner seal. a defender from 1984 pretending to be a puma with a touch of Range Rover |
31st May 2018 3:22pm |
Bump. I still have to do the left side a defender from 1984 pretending to be a puma with a touch of Range Rover
3rd Jun 2018 12:54pm |
So install with the grey ring then? a defender from 1984 pretending to be a puma with a touch of Range Rover
3rd Jun 2018 3:49pm |
