Home > Puma (Tdci) > 2.4TDCi low on power |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 330 |
There is no guarantee for proper function/closing when you hear EGR working. Start with a neu EGR!
If not better: The only things you touched were the two sensors and the VCV. If I were you, I would change them again part by part and check result after each part afterwards. No guarantee that a new part akready has a fault or that you damaged something when cleaning. And they are quite cheap. Good luck! |
16th Feb 2018 1:24pm |
schuee Member Since: 16 Jul 2012 Location: Lincolnshire Posts: 378 |
Hi Landy-Men
Had exactly same symptons as you mate, no DTC's logged and only from reading through DEF2 posts I decided to have the VCV replaced and a pilot learn carried out, having this done resolved my problem See below; http://www.defender2.net/forum/topic30222.html Cheers Keith MY2011 110 XS USW |
16th Feb 2018 1:45pm |
landy-men Member Since: 15 Feb 2018 Location: Maaseik Posts: 2 |
Hi Keith
As I said I had the VCV replaced and that solves the issue of bad running. But since then it is lower on power. Wondered if that was caused by changing the VCV? Regards |
26th Feb 2018 7:48am |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 |
Do you have a OBD diagnostic tool that can probe the EGR position?
In my experience if it doesn't close properly you'll really feel it. Even if you hear the chakka chakka, it doesn't necessarily mean it's closing fully... Solved the bowel problem, working on the consonants... |
26th Feb 2018 8:49am |
