Home > Td5 > Drive shaft play - how much is too much? |
If it is like mine, there is play at every joint in the drive line. So no big play at one point but a little play everywhere making it feel like a lot off play. Roel
10th Nov 2017 9:09pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5740 |
Play in half shafts
Play with wheel on 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
10th Nov 2017 10:13pm |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4395 |
Evening John. That's moderately bad.
Right then mate. one more test; Pop that flange cap off, clean up the area underneath so you can see the splines of the flange and 1/2 shaft. Then repeat your test. You will have a much better idea of whether it is the shaft or the flange that is the problem. I suspect that it will be both the shaft and the flange with a little in the diff. This is something I know I have to replace on the 110, but have been dragging my heels... |
10th Nov 2017 10:36pm |
Cheers chaps. I will have another look tomorrow (assuming no wet stuff is falling) 1999 Defender TD5 110
10th Nov 2017 11:19pm |
I am sorry do I have to remind you of your pledge when you first took up being the caretaker of a Land Rover?
Repeat after me: I shalt not whine or complain should there be precipitation falling form the sky, my Land Rover comes first and should it require attention I shall head the call and answer it with dedication and efficiency...! Now pick up you spanners, coat and head torch and get to it... |
10th Nov 2017 11:22pm |
