Home > Td5 > Drive shaft play - how much is too much?
excossack
While trying to trace a clunk that I get either pulling away or reversing off the drive I checked the rear drive shaft and did find some play, but how much is too much?
I am thinking I may replace both flanges and see if that does reduce drive line sloppiness/clunks
I will upload a video to youtube later that I took of the play.
Anyway, checked for play in rear trailing arms OK
Rear A frame ball joint no movement
Shocks OK.
Wheel bearing OK
Flange bolts tight
Wheel nuts OK
Prop shaft UJs feel OK.
I did find some play in the front trailing arms (the noise could be there) 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #663223 10th Nov 2017 8:40pm
roel
If it is like mine, there is play at every joint in the drive line. So no big play at one point but a little play everywhere making it feel like a lot off play. Roel
2003 90 Td5 (2009-now)
Post #663239 10th Nov 2017 9:09pm
excossack
Play in half shafts
Play with wheel on
Regards
John M0VAZ
Post #663266 10th Nov 2017 10:13pm
geobloke
Evening John. That's moderately bad.
Right then mate. one more test;
Pop that flange cap off, clean up the area underneath so you can see the splines of the flange and 1/2 shaft. Then repeat your test. You will have a much better idea of whether it is the shaft or the flange that is the problem.
I suspect that it will be both the shaft and the flange with a little in the diff. This is something I know I have to replace on the 110, but have been dragging my heels...
Post #663278 10th Nov 2017 10:36pm
excossack
Cheers chaps. I will have another look tomorrow (assuming no wet stuff is falling) 1999 Defender TD5 110
Regards
John M0VAZ
Post #663296 10th Nov 2017 11:19pm
geobloke
I am sorry do I have to remind you of your pledge when you first took up being the caretaker of a Land Rover?
Repeat after me: I shalt not whine or complain should there be precipitation falling form the sky, my Land Rover comes first and should it require attention I shall head the call and answer it with dedication and efficiency...! Now pick up you spanners, coat and head torch and get to it...
Thumbs Up
Post #663298 10th Nov 2017 11:22pm
