Home > Wheels & Tyres > 265/75r16 on boosts |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1411 |
you'll be fine. You might need to adjust the steering locks if you get rubbing on full lock
10th Nov 2017 4:58pm |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
Is that easy?
10th Nov 2017 5:13pm |
yes, and only necessary if they catch
5th post down has a picture http://www.defender2.net/forum/topic39311....ring+stops |
10th Nov 2017 5:17pm |
STEERING
ADJUSTMENT STEERING LOCK STOPS Service repair no - 57.65.03 Check 1. Measure clearance between tyre wall and radius arm at full lock. This must be not less than 20 mm. Adjust 2. Loosen stop bolt locknut. 3. Turn stop bolt as required. 4. Tighten locknut. 5. Check clearance between tyre wall and radius arm on each lock. NOTE: Alternatively lock stop adjustment may be carried out using following procedure. Check 1. Measure stop bolt protrusion ’A’. Refer to table for correct setting. Adjust 2. Loosen stop bolt locknut. 3. Turn stop bolt as required. 4. Tighten locknut. 5. Check wheel position at full lock. LOCK STOP SETTINGS Tyre & wheel size - alloys Make Size Setting BF Goodrich Mud Terrain 265 59,7 mm Goodyear GT+4 235 55,7 mm Michelin M+S 4x4 235 54,2 mm Tyre & wheel size - steel Make Size Setting Goodyear 205 52,2 mm Michelin 205 52,2 mm Avon 7.50 56 mm Michelin 7.50 56 mm Goodyear 7.50 56 mm Last edited by dorsetsmith on 10th Nov 2017 6:09pm. Edited 1 time in total |
10th Nov 2017 5:32pm |
very useful thank you, i may still op forthe 235/85/16 yet , ive been going back and forth in my mind for months now lol. SHame i cn buy both sets and see what looks best
10th Nov 2017 6:07pm |
I have both Prefer the 265 IMHO the 235 is a bit skinny, especially with spacers... Buy the 265, then you can swap for my 235
10th Nov 2017 6:17pm |
do you have stt Pro's?
10th Nov 2017 6:22pm |
No BFG at
10th Nov 2017 6:25pm |
so did you have to adjust your steering stops? Ill probably go with the 265's in the end its just a lotta cash for 5 tyres
10th Nov 2017 6:26pm |
Only ever had to adjust on the new puma to increase the turning circle when it was supplied. I know someone who fitted new tyres and had to alter his slightly though...... Same brand and tyre as take off just new
10th Nov 2017 6:31pm |
L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 716 |
Having had both (of the same tread pattern) there are pros and cons to each.
235/85: Better on fuel. Quieter. Cuts through standing water, snow, mud better. Shouldn't worsen steering lock. Doesn't spray too much muck up the sides. 265/75: Look better. Floats on bogs better and erm that's about it! I like 255/85's best, ideally on Wolf rims! Good luck with the decision! Instagram: l90andy 2006 Land Rover 90 TD5 CSW Silver Edition My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD! My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD! |
10th Nov 2017 6:42pm |
255/85's ah man didn't even know that was an option on standard boosts?
10th Nov 2017 6:54pm |
Yep, Boosts are 7" wide and 255's will go on anything over 6.5". They are a taller tyre so you'll get more clearance than either of the other two so would affect your gearing more. They also tend to come in MT pattern only. All depends what your requirements are. Instagram: l90andy
10th Nov 2017 7:21pm |
Sorry, totally distracted you from your original post! The answer as mentioned above is, yes 265's will fit. A very common and capable fitment. Go for it Instagram: l90andy
10th Nov 2017 7:27pm |
