Home > Off Topic > Securing spare wheel under a Ford Galaxy |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4937 |
an idea for you, can you not retro fit a Peugeot spare wheel cage plus system? a bit of custom diy would be on order, but might be worth looking at. Peugeot/ citroen systems do have a problem of seizing due to the salt etc. I replaced mine last year and we well greeced it up! Also my 306 has a fifth alloy so i have the wheel in a wheel bag too!
Or if possible even find a good second had unit? might be a little tricky to find now, due to the age of the car etc. but worth a look at. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
18th Sep 2017 12:54am |
Sheepish Member Since: 03 Feb 2017 Location: Welsh Marches Posts: 8 |
I had this problem when I bought a 54-plate Galaxy last year.
Got second-hand one of ebay for £55, and just found this one with a simple search. Clearly, I cannot vouch for it.................... http://www.ebay.co.uk/itm/FORD-GALAXY-SHAR...SwaMpZo-0K |
18th Sep 2017 10:42pm |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1294 |
Reply - thanks thats useful.
However, reluctant to spend £50 on something sol old and rusty - no guarantee that it is in working order |
19th Sep 2017 10:29am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5743 |
Maybe a pen and paper time and draw up something of your own design and then off to a metal fab place to make it for you ? 1999 Defender TD5 110
19th Sep 2017 1:24pm |
Yup thats more along the lines I have been thinking. Or if someone has adapted some existing piece of kit for this purpose
19th Sep 2017 1:49pm |
jrule Member Since: 10 Aug 2015 Location: Hertfordshire Posts: 302 |
Land Rover wheel carrier on bonnet…
19th Sep 2017 1:54pm |
Spare wheel in side ford galaxy as had same problem ford Transit spare wheel carer and got rid of the jack at same time as not fit for the job and safely remove wheel and tyre van loaded
19th Sep 2017 2:11pm |
Or a Mantec swingaway on the rear... Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
19th Sep 2017 2:17pm |
Mr Dorset Smith - please tell more about the Transit Wheel Carrier?
Which one did you go for and was it easy to fit? |
19th Sep 2017 3:06pm |
Not possible with a Ford Galaxy - have you seed the bonnet? Re swing away - I really want to store the wheel under the car - just need a convenient way to secure it there - its an old steel wheel so no one would want to nick it |
19th Sep 2017 3:07pm |
Spare wheel in side ford galaxy as had same problem ford Transit spare wheel carer ford Transit used same system your have problems with repaired 3 time by fords, 4th time the spare wheel moved inside back van and long time before that the jack had failed (almost lost one hand) replaced by 3 ton trolley jack (field service van one the go 24.7 most weeks) |
19th Sep 2017 3:22pm |
