Home > Td5 > Wiper problems. |
kweese Member Since: 28 Apr 2015 Location: Van Posts: 62 |
Greetings.
I have an issue with my front wipers. They do not go back to the normal seating position if I turn it to the off position. It will stop a half second or so after I turn it off and it will stay where it is instead of going back down to the lower windshield position. What can be wrong? I was thinking the relay. If so, should I upgrade it to the one that people suggest from a VW? What is that part number? I'm in Canada, is there a part number from another vehicle that I can use that is sold in Canada,? Thanks again |
9th Sep 2017 10:17pm |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 832 |
Wiper motor park switch has packed up. Can be replaced fairly easily. This thread explains all!
defender2.net/forum/topic2031.html?highlight=wiper+park+switch Just because you're offended doesn't mean you're right. |
9th Sep 2017 10:37pm |
Wiper motor park switch has packed up. Can be replaced fairly easily. These threads explain all!
http://www.defender2.net/forum/topic2031.html?highlight=park http://www.defender2.net/forum/topic21058.html?highlight=park http://www.defender2.net/forum/topic18132.html?highlight=park http://www.defender2.net/forum/topic11239.html?highlight=park Just because you're offended doesn't mean you're right. |
9th Sep 2017 10:40pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19578 |
I have the ideal solution:
http://www.bbc.co.uk/news/uk-england-birmingham-41212203 Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
9th Sep 2017 10:42pm |
Steve
You've found a dealer fitted option for the new Defender! |
10th Sep 2017 12:46pm |
Is there a park switch on both motors? also, my defender is LHD.
11th Sep 2017 1:48am |
There's only one motor for the front wipers. On a LHD vehicle, it's located behind the RH end of the dash. It drives both wipers via a flexible spiral drive rack. The park switch will be the same regardless of which side the motor is mounted. Darren
11th Sep 2017 8:12am |
