Home > Td5 > Power Steering pump |
Cactus79 Member Since: 09 Jan 2017 Location: Cheshire Posts: 51 |
From doing it the other week best bet is just replace, pretty simple job. I also did the water pump at the same time but probably didn't need to after inspection of the old one.
10th Sep 2017 6:08pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
Yeah I was coming to that conclusion! Having had a look it's leaking fluid from thejoin between the LP and HP sides. Replacement on the cards. Do I need to remove the viscous fan to get it out? Thanks for replying!
10th Sep 2017 6:16pm |
Viscous fan off does give you a bit more room and is easier to sort the drive belt
10th Sep 2017 8:54pm |
Aand flatdog viscous fan spanners are only £16. Decision made!
10th Sep 2017 10:32pm |
