Home > Td5 > Power Steering pump
miker
Power Steering pump
So a week ago, I noticed my PAS was a bit noisy
Yesterday there was a puddle of PAS fluid underneath the car, reservoir is low, and the fluid appears to be originating from the pump.
Is my pump goosed or is there some seal kit I might be able to replace? Going to have a closer look at it today!
Post #648965 8th Sep 2017 9:49am
Cactus79
From doing it the other week best bet is just replace, pretty simple job. I also did the water pump at the same time but probably didn't need to after inspection of the old one.
Post #649385 10th Sep 2017 6:08pm
miker
Yeah I was coming to that conclusion! Having had a look it's leaking fluid from thejoin between the LP and HP sides. Replacement on the cards. Do I need to remove the viscous fan to get it out? Thanks for replying!
Post #649387 10th Sep 2017 6:16pm
JWL
Viscous fan off does give you a bit more room and is easier to sort the drive belt Thumbs Up
Post #649440 10th Sep 2017 8:54pm
miker
Aand flatdog viscous fan spanners are only £16. Decision made!
Post #649486 10th Sep 2017 10:32pm
