Home > In Car Electronics > In car security cameras |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5024 |
There are plenty of different types of CCTV cameras available, depending on what exactly you want eg a dash cam type with park power, a conventional cctv camera or a wildlife type camera.
Some things you will need to consider is location and power, as well as good night vision. If you have a good camera with night vision, check that the IRs arent going to reflect on the glass and therefore not give you a view outside. The biggest issue is that a cctv camera will only record them steeling it, rather than stop them (maybe a mild deterrent) Is the car port area yours, could you add some external cameras? Mike |
28th Aug 2017 2:09pm |
