Home > Td5 > Transform your TD5 90/110 for £250 |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7873 |
Nice to read, but... what dampers?
Also out of interest how do you adjust the dampers? Is it an easy job, if you were in the mood for sports mode? James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
21st Jul 2017 5:10pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2069 |
Good news! I'm currently working on an electronic in cab system to adjust dampers. If the TF adjustable ones that you have are good I only imagine the more expensive ones will be better.
21st Jul 2017 5:29pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2240 |
Yeah l fitted the Terrafirma ones.
Adjustment is easy but you do have to get on the floor to turn the knobs on the bottom of the dampers. They have four positions with a detent on each position. The front ones are a little harder to adjust as you need to get your fingers between the coil spring. But it only takes under a minute to do all four. To be honest it handles well at speed/on the motorway even in the softest setting. l do have ARB's on the Defender though. |
21st Jul 2017 6:22pm |
