Home > Td5 > Exmoor trim seat heater fitting instructions/video |
Gareth Member Since: 12 Dec 2011 Location: Bramhall Posts: 1038 |
Just got a seat retrim kit, along with new heaters. Great instructions and video for replacing the foams and covers, but no instructions for the seat heaters.
Can someone point me to a PDFs or video? 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
6th Jul 2017 6:27pm |
proloForêt Member Since: 16 Mar 2017 Location: Montereau Posts: 248 |
I have this kit for the OEM version of heaters and it say in the retrim kit what to do. Stick on and that is it, wire plug already under seat.
6th Jul 2017 6:48pm |
Yes all the wiring us there, just not sure which way up the heater pads go, taped sides up,or down? Also do I glue the Heater pads to the foam, and then the cover to the heater pads?
The Exmoor video on YouTube shows fitting covers and foams without heater pads. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
6th Jul 2017 7:52pm |
The instructions with the trim kit shows the pictures, you can see they are using the heater kit from illustration 12.
You stick the large part of the pad down on the foam, the seat back. To do this you peel off the white wax paper on the heating pad, and stick that to the seat back foam with the wire that is wired point down. The smaller pad goes to the foam for the piece which accept the buttocks and the wire go to the back with the other and come out the back then under to the plug. Easy. Then you put on the coverture over the top of this. Do the heater pad first, do not put on the coverture until you have sticked the pads. |
6th Jul 2017 9:13pm |
Do I glue the seat cover to the heater pad? 2021 Defender 110 X-Dynamic HSE D300 MHEV
7th Jul 2017 6:59am |
