Home > Td5 > Exmoor trim seat heater fitting instructions/video
Gareth
England 2003 Defender 90 Td5 CSW Oslo Blue
Just got a seat retrim kit, along with new heaters. Great instructions and video for replacing the foams and covers, but no instructions for the seat heaters.
Can someone point me to a PDFs or video? 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
1968 S2a 88 aka Bob
2014 Jaaaag F Type 3.0 Supercharged.
Post #635992 6th Jul 2017 6:27pm
proloForêt
France 2008 Defender 90 Puma 2.4 XS CSW Java Black
I have this kit for the OEM version of heaters and it say in the retrim kit what to do. Stick on and that is it, wire plug already under seat.
Post #635996 6th Jul 2017 6:48pm
Gareth
Yes all the wiring us there, just not sure which way up the heater pads go, taped sides up,or down? Also do I glue the Heater pads to the foam, and then the cover to the heater pads?
The Exmoor video on YouTube shows fitting covers and foams without heater pads. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1968 S2a 88 aka Bob
Post #636006 6th Jul 2017 7:52pm
proloForêt
The instructions with the trim kit shows the pictures, you can see they are using the heater kit from illustration 12.
You stick the large part of the pad down on the foam, the seat back.
To do this you peel off the white wax paper on the heating pad, and stick that to the seat back foam with the wire that is wired point down.
The smaller pad goes to the foam for the piece which accept the buttocks and the wire go to the back with the other and come out the back then under to the plug. Easy.
Then you put on the coverture over the top of this.
Do the heater pad first, do not put on the coverture until you have sticked the pads.
Post #636039 6th Jul 2017 9:13pm
Gareth
Do I glue the seat cover to the heater pad? 2021 Defender 110 X-Dynamic HSE D300 MHEV
1968 S2a 88 aka Bob
Post #636126 7th Jul 2017 6:59am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Yes 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #636291 7th Jul 2017 9:10pm
