Home > Maintenance & Modifications > Rear LED lights |
Mudstuff Ray
2nd Jul 2017 3:12pm |
Mobilecentre
I also suggest that you carefully read through the entire thread I copy here below before buying a set of rear SVX style lights. http://www.defender2.net/forum/topic11782....lights+fit Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
2nd Jul 2017 3:54pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2078 |
Mud.UK.
Mo The Land Rover 90 - Many are called, few are chosen. |
2nd Jul 2017 4:19pm |
stephan123 Member Since: 18 Mar 2015 Location: London Posts: 281 |
Thanks guys! Looks like Mobile Centre is the best option for peace of mind!
2nd Jul 2017 5:49pm |
Probably right. And when you compare the prices and you see that Mobilecentre is a price everything that is needed included, but with Mud you still have to buy the plinth for each lamp separately at 9.60£ a piece, the first is going to work out better too. I have bought things from both companies, always good experiences, but Mobilecentre also are a site sponsor on here.
Eric P.S. I suggested that you would read that copied thread carefully, just be aware that you may have to drill new holes in your rear panels for these 95mm plinths. Not exactly plug 'n play compatible if you have standard lights now. You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
2nd Jul 2017 6:07pm |
I've got the RDX ones.
http://www.ebay.co.uk/itm/RDX-Td5-Tdci-LED...3614efb569 |
2nd Jul 2017 6:41pm |
You don't have to drill holes in the rear panel! Just drill holes in the plinth to match your existing rear panel clips. Ray My build thread http://www.defender2.net/forum/topic17615.html |
2nd Jul 2017 6:47pm |
Probably right. It is a long time ago, but the need for new holes drilling was mentioned in the below thread. Which seems only the case when using non genuine 95mm plinths.
http://www.defender2.net/forum/topic16405....holes+rear You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
2nd Jul 2017 7:07pm |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 372 |
i purchased mine from Dun Bri Group. Genuine Perei make. Really good price. Found some plinths on eBay (correct ones) and then a bit of wiring and sourced connectors ,as luckily this is my line of work. All in about £210
But as recommended on here by others, the kits supplied ready to go are also good and will save you money 2015 90 XS Santorini Black |
2nd Jul 2017 8:53pm |
Is it possible to screw the rear lights from the back? If I'm going to spend several £100s on lights I want to make sure they are at least thief proof!
8th Jul 2017 7:11pm |
I'm not really sure how you'd do it. You could just buy some security screws and screw them in from the front as usual. Obiously all security screws have tools readily availiable to undo them, but it makes it a bit more difficult for the oportunist in a car park.
9th Jul 2017 12:39pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3693 |
Alloy plinths and lights from CSI parts, Great stuff I like them (still need to change the fog and reverse light plinth)
Click image to enlarge Click image to enlarge Click image to enlarge Much brighter and imho safer than the OEM ones. |
9th Jul 2017 9:21pm |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
the csi plinths do not fit the oem perie light units.
10th Jul 2017 4:30pm |
I've just had an email from Thomas at CSI saying he's getting some of the plinths machined up next week to fit perei lights after I gave him all the measurements. Ray
My build thread http://www.defender2.net/forum/topic17615.html Last edited by mk1collector on 10th Jul 2017 4:47pm. Edited 1 time in total |
10th Jul 2017 4:44pm |
