Home > Td5 > TD5 - Fuel in the coolant! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19574 |
Are you sure the fuel cooler pipes are the right way around?
On the Puma the two are right next to one another, not sure about the TD5? So you have diesel and coolant passing through, in separate pipes right next to one another. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
30th Jun 2017 5:13pm |
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 430 |
Hope so it was fitted by Gem 4x4 a Land Rover specialist!
30th Jun 2017 5:16pm |
Anyone got an idea?
30th Jun 2017 9:43pm |
Td5 runs an internal fuel rail in the head. Worst case it could be a cracked head or head gasket. 2002 90 Td5 Station Wagon
30th Jun 2017 9:59pm |
Would there not be other symptoms?
How would I suss that out? |
30th Jun 2017 10:03pm |
I think a pressure test would be a good option 2002 90 Td5 Station Wagon
30th Jun 2017 10:08pm |
If you've replaced everything where fuel and coolant interact then there isn't much else it could be I wouldn't have thought? 2002 90 Td5 Station Wagon
30th Jun 2017 10:09pm |
So what's a new cyclinder head gona cost?
30th Jun 2017 10:22pm |
Around 1000+vat but I think there is possibly some more investigation to be done first. I'm only going on a hunch 2002 90 Td5 Station Wagon
30th Jun 2017 10:36pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16879 |
If the 'O' rings in the cooler haven't been correctly fitted it may still be leaking.
30th Jun 2017 10:46pm |
Cheers, will take it back to the garage next week! Hope its that!
30th Jun 2017 11:01pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 539 |
Did it have a new fuel cooler or seals replaced? The seals only stop coolant leaking to atmosphere, inside there is tubes which the fuels flows around, these are welded stainless which could possibly crack.
When the seals on the injectors leak you would expect oils level rising. Kind Regards Will 2005 90 XS 1954 86'' Series 1 tilt |
30th Jun 2017 11:23pm |
It had a brand new fuel cooler fitted?
1st Jul 2017 4:12am |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
Are you 100% sure it's fuel in the coolant, not oil? it's a Landrover thing...
my renovation thread: http://www.defender2.net/forum/topic40792.html |
1st Jul 2017 4:56pm |
