Home > In Car Electronics > Advice please, installing a sub to standard XS alpine radio |
Can you not just use the remote wire on the back of the headunit? If you have no other ice I can't see why it would be used already. Ray
10th Jun 2017 7:12pm |
Jimbob Member Since: 17 Mar 2011 Location: Gower Posts: 68 |
There wasn't one there weirdly! The blue/white wire which is amp remote/aerial raise according to the schematic was only going into the head unit in the block connector, no loose end or other connection there, I can only presume it's part of the factory wiring, and I'd have to tap into it which there wasn't enough room to do so? 2009 Defender County Hard Top (gone 😞)
1990 200tdi defender off roader 2015 Defender XS Hard Top (awaiting delivery 😄) |
10th Jun 2017 8:21pm |
What do you mean by tap into it? The wire should come out of the plug in the back of the headunit and maybe run into a multi plug then usually out the other side to nothing. Ray
10th Jun 2017 11:43pm |
Yeah for some reason it goes into the block but doesn't come back out? There's no loose end to connect to like normal 2009 Defender County Hard Top (gone 😞)
11th Jun 2017 9:23pm |
If it goes into the block then just cut it and put a terminal on. Ray
11th Jun 2017 11:11pm |
It's just suddenly dawned on me why it's connected, would there be the plug under the cubby box for the extra Sub option? I thought this wasn't available on the 90 only the 110 or could it be there? I'll check when I have chance 2009 Defender County Hard Top (gone 😞)
15th Jun 2017 8:42pm |
glpinxit Member Since: 31 Jul 2010 Location: Somerset Posts: 149 |
No plug in my MY14 90 XS so had to wire from scratch. Cheers, Guy.
22nd Jun 2017 9:32pm |
