Home > Tdi > 1993 side indicator removal |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2078 |
It is pushed in on tapered pins moulded onto the base, sometimes with a self adhesive pad across the base.
It will need therefore to be gently prised off. HTH Mo The Land Rover 90 - Many are called, few are chosen. |
8th Feb 2017 12:30pm |
Ooh, thanks for that. It's a question I've been meaning to ask myself as on mine, one side has been replaced but the other side is the original.
The replacement is fitted with small nuts and bolts and it's possible to get access to the rear by taking out the headlight. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
8th Feb 2017 1:19pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5084 |
From what I recall the answer is No as the inner wing is in the way. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
http://www.youtube.com/user/conwy1 |
8th Feb 2017 4:59pm |
What question are you answering? Darren
8th Feb 2017 5:53pm |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 526 |
Mine was held on by a self adhesive pad and some pins that push into the body work. heating it with a hair drier should help loosen off the adhesive, then pull gently but try not to pull the lens off the fitting... I replaced mine with a new one as I pulled the lens off the fitting I was unable to get access to the back due to the inner wing as stated.. but the wires are long enough to reach though, I have to use a small set of steps....
Mine is a 1993 200tdi |
8th Feb 2017 6:01pm |
