Home > Td5 > TD5 Interior Lights only activated by drivers door. |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4395 |
Is it normal for just the drivers door to activate the interior lights in a TD5 Defender?
For the life of me I cannot recall noticing it before. Guess it is just one of those things I have taken for granted... Could this be just a setting in the 10AS alarm module? |
30th Jan 2017 7:12pm |
If the other doors are rarely used then the switches can start to play up 2002 90 Td5 Station Wagon
30th Jan 2017 7:44pm |
Nick666 Member Since: 23 Mar 2016 Location: Somerset / Dorset borders! Posts: 81 |
Am I right in remembering the door switches earth through the mounting screws? My driver's door one was a bit sticky but freed up easily enough.
31st Jan 2017 12:42am |
Yes they earth through the screw 2002 90 Td5 Station Wagon
31st Jan 2017 1:03am |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 157 |
If you have diagnostics, it's easy to check.
Look for passenger door and driver door. Just work the switches and they should show you high or low. All doors are passenger doors while driver door is separate. Failing which if you can't solve it, just connect them all to the driver door. It doesn't make a difference. The only difference is that the eka is entered through the driver door, so now you can also use any other door. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island. |
31st Jan 2017 11:12am |
Thanks guys. Ok. Well I replaced all the switches a year ago, so perhaps it is a bad connection through the retaining screw. Kinda strange that they have all gone faulty at the same time.
Hi Achuakh I do have a nanocom, but I am still getting to grips with it. I assume that the this is in the 10as section. Will go and have a look. Another job to add to the list |
4th Feb 2017 11:50am |
sent you PM re 10AS
4th Feb 2017 1:45pm |
bogwert Member Since: 03 Sep 2016 Location: Dundee Posts: 194 |
6th Feb 2017 10:11am |
Hi Bogwert, same here that is all it turned out to be. It is amazing how you can take automatic lights for granted, to the extent of not being certain that it has ever worked... Ludicrous...
6th Feb 2017 7:04pm |
I'm sure there must be a better switch solution than the factory. It's a pretty unreliable design! 2002 90 Td5 Station Wagon
6th Feb 2017 10:02pm |
