Home > Td5 > TD5 Interior Lights only activated by drivers door.
geobloke
Is it normal for just the drivers door to activate the interior lights in a TD5 Defender?
For the life of me I cannot recall noticing it before. Guess it is just one of those things I have taken for granted... Rolling Eyes Rolling Eyes
Could this be just a setting in the 10AS alarm module?
Post #597698 30th Jan 2017 7:12pm
Romadog
Check the switches on the other doors.
Connections, function etc.
Remove wire and touch to earth, light should illuminate.
Post #597702 30th Jan 2017 7:23pm
grafty99
If the other doors are rarely used then the switches can start to play up Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #597712 30th Jan 2017 7:44pm
Nick666
United Kingdom 1986 Defender 90 2.5 n/a Diesel SW Yellow
Am I right in remembering the door switches earth through the mounting screws? My driver's door one was a bit sticky but freed up easily enough.
Post #597932 31st Jan 2017 12:42am
grafty99
Yes they earth through the screw Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #597933 31st Jan 2017 1:03am
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
If you have diagnostics, it's easy to check.
Look for passenger door and driver door. Just work the switches and they should show you high or low.
All doors are passenger doors while driver door is separate.
Failing which if you can't solve it, just connect them all to the driver door. It doesn't make a difference. The only difference is that the eka is entered through the driver door, so now you can also use any other door. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
Post #597973 31st Jan 2017 11:12am
geobloke
Thanks guys. Ok. Well I replaced all the switches a year ago, so perhaps it is a bad connection through the retaining screw. Kinda strange that they have all gone faulty at the same time.
Hi Achuakh I do have a nanocom, but I am still getting to grips with it. I assume that the this is in the 10as section. Will go and have a look.
Another job to add to the list Rolling Eyes
Post #599030 4th Feb 2017 11:50am
dorsetsmith
sent you PM re 10AS
Post #599049 4th Feb 2017 1:45pm
bogwert
Scotland 2003 Defender 90 Td5 CSW Zambezi Silver
Had a similar issue on ours with the passenger door. turned out the clip wasn't seated right on the switch.
It was as simple as take it off and seat it back home... done! Chris
2014 Discovery 4 TDV6 HSE
2003 Defender 90 TD5 CSW
Post #599492 6th Feb 2017 10:11am
geobloke
Hi Bogwert, same here Thumbs Up that is all it turned out to be. It is amazing how you can take automatic lights for granted, to the extent of not being certain that it has ever worked... Ludicrous... Rolling Eyes
Post #599641 6th Feb 2017 7:04pm
grafty99
I'm sure there must be a better switch solution than the factory. It's a pretty unreliable design! Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #599703 6th Feb 2017 10:02pm
