Home > Td5 > Miles from fresh tank? |
Well call me a liar if you want but I can get 400 miles from a tank. What do I have to gain by lying about it?
Currently on 205 miles with way more that half a tank indicated...... Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
31st Dec 2016 10:10pm |
isacs Member Since: 28 Aug 2015 Location: Leamington spa Posts: 404 |
Grafty....you running regular diesel or high quality?
1st Jan 2017 3:39pm |
I run standard diesel with 350ml of two stroke oil per tank.
I use Shell v-power or BPultimate when I need fuel near one of the two. None near home though so mainly texaco + 2 stroke oil which is our nearest 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
1st Jan 2017 4:08pm |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2874 |
Grafty how many miles after fuel light comes on do you fill up
Light usually on at about 370 2002 90 Td5 Station Wagon
1st Jan 2017 4:09pm |
So around 30 2002 90 Td5 Station Wagon
1st Jan 2017 4:10pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1411 |
you sure you've not turned into Miss Daisy ??? I'm be halfway through my 2nd tank |
1st Jan 2017 4:41pm |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 999 |
That is remarkable.
1st Jan 2017 5:05pm |
Don't worry I still get a wriggle on when the occasion calls 2002 90 Td5 Station Wagon
1st Jan 2017 5:17pm |
mactheknife Member Since: 08 Jul 2016 Location: Somerset Posts: 51 |
Grafty, why do you add the two stroke oil?
1st Jan 2017 5:31pm |
using the 2.2 everyday means when I am allowed the TD5 I'm a kid in a sweet shop The noise
1st Jan 2017 5:32pm |
The noise is very addictive, it does take quite a bit of self control
I add 2 stroke oil because current low sulfur diesel has very few lubricating properties. The 2 stroke oil lubricates everything from the fuel pump to the injectors. I notice much smoother and quieter running with the 2 stroke oil. If you have a search on Google I'm sure you will find a much more technical explanation than mine. Just clicked over 117k miles on the original fuel pump so it must do something as Td5 fuel pumps aren't the most reliable 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
1st Jan 2017 5:57pm |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2163 |
http://www.defender2.net/forum/topic29456.html
Oh hear we go again ......... " did you hear that 600 miles is possible in a defender " |
1st Jan 2017 6:24pm |
I'm surprised that it works out to be 30mpg - that's what I'm getting, but my light comes on at 330 and the most I've put in is around 55 litres..... so maybe if I kept going I'd get 400 too?
Have you ever run out of fuel? Or suffered from crap in the bottom of the tank with running it so low? |
1st Jan 2017 6:39pm |
