Home > Technical > Side/main dash light not working and some side lights off |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
Its finding the time while daylight thats the issue for me ATM, OK update as of today, i spent yesterday hose piping the back end down to clean it and I managed to find this multi plug and disconnect the trailer loom, the plug was clean and dry and in good condition, I had to cut it to extract it from the vehicle so its no good anymore I went for a drive this morning and the same thing happened, side lights worked ok for about 5 minutes, and the fuse has blown again
Its the same fuse as the Registration plate bulbs, but they are dry also, although one bulb has gone. Does anyone know if this circuit has any other bulbs/devices on it apart from half the side lights and the registration lights, also where any other potential weak points might now be? Its fuse F18 thats blowing Thanks JD 2008 TDCi 2.4 XS CSW |
31st Dec 2016 2:07pm |
OK finally solved, and it took me some finding let me tell you........I found a wire with a tag on it not connected to anything, but lurking around near a relay with other connectors, I moved it out of the way and into the open and the problem has gone, so I am guessing it was making contact with some of those other wires and causing a short. See the pic below.....
There is a black relay behind the white connection that the stray wire was touching, I am guessing that relay is lighting? the truck has been fitted with two extra spots at the front, maybe something to do with that? https://www.dropbox.com/s/6abznb1dfj0o3w7/IMG_0038.JPG?dl=0 JD 2008 TDCi 2.4 XS CSW |
12th Feb 2017 1:59pm |
