Home > My Defender > A second 110 on the drive - 300tdi csw BMW powered! |
lb73 Member Since: 27 May 2016 Location: North Wales Posts: 287 |
Don't mind the rain actually - can mean overtime in work which can come in handy.
Anyway finally got round to finishing the carpet off in the rear. I was under the impression that it would be fairly straightforward. However I think I turned out to be the most awkward part, mainly down time the fact of having to cut round the internal roll bar mounts and trying to make a neat job of the joins of the front part of the rear wheel arch. So all in all I must have took over a day to do it. Anyway it doesn't look too bad a finish and it's the last major job (for now) that I'm going to do. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Pretty pleased with how the front now looks Click image to enlarge Click image to enlarge Also I managed to get round to removing/refitting the o/s rear sliding window as it was leaking water thanks to a lack of rivets and some poorly applied bathroom sealant Click image to enlarge Managed to get good friend (whose a windscreen fitter) to bond and rivet it back in place so now more leaks hopefully. Lastly fitted the decals to the drivers side of the vechicle, I don't think this side when on as well as the other side - few more air bubbles but it still looks ok, don't think it helped being dropped sticky side down on the gravel drive 1999 300TDI 110 CSW BMW 3.0 1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric Last edited by lb73 on 19th Dec 2017 9:15pm. Edited 1 time in total |
1st Oct 2017 7:42pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7873 |
Great work, looks really good! James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
1st Oct 2017 8:47pm |
Cheers 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
1st Oct 2017 8:54pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10513 |
Looking great with the carpet fitted, very nice 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
1st Oct 2017 9:39pm |
Thanks 1999 300TDI 110 CSW BMW 3.0
1st Oct 2017 9:45pm |
Small update - having not done to much to it the last 6 weeks or so I decided to remove the orginal front speakers to something half decent to match the ones in the rear, so splashed out on some 4inch pioneers, which seem to be a big improvement and a good price for £20
Click image to enlarge Also I got round to fitting the heated seat switches to work the elements in the puma seats that came fitted to the vechicle when I bought it - although not o/e they don’t look to bad in the cubby box, just got to finish wiring them up. Click image to enlarge 1999 300TDI 110 CSW BMW 3.0 1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
19th Dec 2017 9:13pm |
Nice little up grades there it's good when you can hear the music with better speakers
Great that all has been ok with the landy 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
20th Dec 2017 10:13pm |
Thanks Clayton, I must admit I’ve been pleasantly surprised by how little has gone wrong since it’s been back on the road. There’s still a few jobs left to do but they are all pretty minor. 1999 300TDI 110 CSW BMW 3.0
22nd Dec 2017 11:09pm |
I think that's down to you making sure it was all ok before you got the mot on it yes they are good to have loads of trouble free miles in
Nice to hear that you have got down to the minor jobs to do Have a good one 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
24th Dec 2017 9:38pm |
Cheers - you too 1999 300TDI 110 CSW BMW 3.0
24th Dec 2017 11:12pm |
Having spent numerous hours removing all the crud of the chassis when I first bought it, I thought I’d try and eliminate it happening again. So I had some thick plastic sheet lying around, so after making some brackets and adding some stainless bolts I was left with this.
Click image to enlarge Click image to enlarge Click image to enlarge It fits pretty well so the majority of crud should be kept of the surrounding parts of the chassis, just got to do the other side to do 1999 300TDI 110 CSW BMW 3.0 1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
14th Jan 2018 9:20pm |
At least your halfway there looking good by the way 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
14th Jan 2018 10:23pm |
CHeers, just got to muster the motivation to do the other side now 1999 300TDI 110 CSW BMW 3.0
17th Jan 2018 11:10pm |
Took another family vw to the paint shop a few weeks back. It’s been the first time I’ve towed with this one, and I was surprised how well it pulled compared to my old works puma. Admittedly it’s got less weight in the back compared to the works one but nevertheless I was pretty pleased with it, considering it’s the older less powerful 300tdi
Click image to enlarge Also managed to resolve the annoying issue of having no working courtesy light for the past few months, after having the alarm module tested and checking all obvious potential faults, I finally traced it down to a multi plug located behind the fuse box. So to celebrate I fitted a couple of led bulbs in both interior lights. I also repaired the bonnet switch which one of the previous owners had cut the wires on Also did an oil change, along with redoing the sump gasket, taking the sump off I discovered that the front of the sump was pretty corroded so I ended up grinding it back and adding some more metal in with the mig. Ideally a new sump would be the way to go but I’ll see how this fairs, doesn’t look to bad now it’s painted up and refitted. Finally I’ve picked up a 300tdi discovery transfer box with the higher ratio, so that will be fitted in the next month or so, along with a new clutch as well. 1999 300TDI 110 CSW BMW 3.0 1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
3rd Mar 2018 9:55pm |
