Home > Technical > Isolation Switch Puma Starter Motor AMP Question
X4SKP
Hello All
Q...What AMPs are drawn by the Starter Motor on a PUMA Engine... Question
Reason for asking is that I'm getting round to adding a few (more) Security Layers
one of which is the installation of an Isolation Switch.
Often described as a 'Battery Isolation Switch', I'm considering the various
options for incorporating one (beyond a cleaver tamper-proof location on the vehicle).
One approach could be to Isolate only the Power Feed to the Starter Motor,
(thereby maintaining the Power Feed from the Battery (underneath front passenger seat)
to the Main Fuse Box (under drivers seat) and its distribution on-wards to the ECU
/ Alarm (etc)... I'm modifying this cable as well due to the inside...outside...inside route this
'vital' cable currently takes... Exclamation )
Exploring the Isolator Switch Options, I see that the Starter Motor Feed is clearly identified... Thumbs Up
and the cable initiates from the + Battery Terminal via a 500AMP Mega Fuse (see below)
clamping to the Mega Fuse with a M8 Stud.
I have (or are getting soon) a Durite Security Battery Isolator Switch
with a description of being rated at '100A @ 24V, 500A for 5 secs'.
(also using M8 cable fixing studs)
So my question is what AMPs are drawn by the Starter Motor on a PUMA Engine when starting
and therefore is this Isolator Switch up to the job, if I go down the route of targeting the Starter Motor... Question
Who knows their electrickery... observations welcome, (including alternative routes / options)
DURITE Security Battery Isolator Switch
http://www.vehicle-wiring-products.eu/prod...tor-switch
+ Terminal Puma Battery (2.4 MY2011)
Main Red Cable from + Terminal marked as BATT TO STARTER
Main 'Starter Motor Cable' removed from Terminal showing 500 AMP Mega Fuse connection
with thanks... SKIP
Post #542466 22nd Jun 2016 5:47pm
Cupboard
Rather than putting it cutting off the starter, why not just stop the control circuits?
It will quite happily run without the starter (you can bump start it) but it won't run without the computers.
Post #542492 22nd Jun 2016 6:55pm
X4SKP
Thanks Cupboard...how do I identity the power feed to 'the computers' / (assume ECU) is this a wise approach? and a completely separate system to the OEM Alarm, thanks again... SKIP
Post #542525 22nd Jun 2016 8:23pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I wouldn't bother with the starter motor. I'd go for killing the fuel pump. You would only need a small switch then which is much easier to conceal and everything would appear normal except it wouldn't fire up. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #543047 24th Jun 2016 4:34pm
Fifth Horseman
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Won't work on the 2.4 puma as no lift pump fitted.
Interrupt the switched supply to the engine ECU or you could consider isolating the injectors although this would be more work to conceal the additional wiring.
Post #543055 24th Jun 2016 4:57pm
Or the crankshaft or camshaft position sensors.
Post #543062 24th Jun 2016 5:14pm
Cupboard
On mine there's a big cable for the starter and a medium sized cable for everything else. At least that's what I remember.
Post #543070 24th Jun 2016 5:55pm
X4SKP
Thanks for this feedback
Q Has anyone added an Isolation Switch to a PUMA tdci, to prevent it from Starting... Question
(but maintaining all 'essential' systems Alarm / Central Locking / and permanent lives (Tracker)
and possibly other 'aspects' that should not be Isolated...)
There are a number of threads on D2N discussing Battery Isolation Switches, and various
ideas are explored, a few have asked 'similar' questions...but most threads fizzle out...
Has anyone actually done this...on a PUMA... Question
Happy to receive a PM if you would prefer... Cool
Thanks SKIP
Post #543071 24th Jun 2016 5:58pm
X4SKP
Hi Cupboard
You are right the RED Cable is direct to the Starter (Bottom of Picture)
The Black Shielded Cable (Brown inside) supplies the Main Fuse Box (Right of Picture)
The Black Cable (Left of Picture) is my additional 13 PIN Electrical Feed for Towing
I don't think upstream of the Main Fuse Box (under drivers seat) you Isolate this wire...nothing will work,
down stream maybe, keeping essential features alive (Alarm etc)... I'v posted a question (above) to try and see who knows what...
 SKIP
Post #543076 24th Jun 2016 6:10pm
