Home > Td5 > TD5 110 - Utility Wagon Side Panels
dasowak
Germany
Hey,
I'm looking for rear side panels without side windows (preferably with the windows in the back) for a TD5 Defender (build 2004)
At the following picture you can see what I mean:
Does somebody know a part number of what I'm looking for and can help me?
Best regards from Germany
Paul
Post #518386 28th Mar 2016 10:39am
Fatboy Slim
Wales
Ah the utility side panels you mean. I've just managed to get my hands on a pair the proper ones are quite rare
Post #518389 28th Mar 2016 10:48am
Anderzander
Don't the 88" ones fit ?
Post #518392 28th Mar 2016 11:07am
Fatboy Slim
Wales
88 ones do fit but there's a vertical strip by the door frame and the internal strengthening rib is horizontal instead of vertical, so if you wanted to put mud stuff interior panels in it etc it's going to be a lot more work
Post #518397 28th Mar 2016 11:17am
dasowak
Germany
Wow Shocked - thanks for your quickly replies Smile
Do the utility wagon side panels from a TD4 fit in a TD5 without doing a lot of adjustments? And is there any shop in the UK where I can order these panels? I've already searched in a lot of different forums and I can't find an answer.
In German Forums the most members say that these panels are quite expensive and that I should remove the side windows from our defender, take a painted plate and stick it at the side.
Paul
Post #518402 28th Mar 2016 11:42am
Fatboy Slim
Wales
Yep puma ones will drop straight in. I've got a pair here that I'm waiting to paint when the weather improves. Took me 12 months of searching to find them.........
Post #518405 28th Mar 2016 11:51am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
I have a set of a 1984 90. But I don't know if that will fit a 110. They will fit a 90 td5.
I think you are looking for 110 panels but that is not mentioned in your post.
Where do you live in Germany? I will probably be in furstenau in may. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #518430 28th Mar 2016 2:49pm
Anderzander
90 panels are too long sadly.
Post #518440 28th Mar 2016 3:15pm
dasowak
Germany
Oh sorry... I'm looking for the TD5 110 side panels.
So if I understood you right the following panels are 88" side panels, because of the horizontal strengthening rib, aren't they?
And is there maybe a Shop in UK where I can order the PUMA Utility Wagon side panels???
Thank you all for your amazing and quickly support! Bow down Thumbs Up
Paul
Post #518455 28th Mar 2016 4:21pm
Loz2286
Dingocroft in High Wycombe may be able to source them. They are happy to sort shipping too.
www.dingocroft.co.uk 1999 Td5 110 CSW
1961 Series 2 88 LPG
Post #518622 28th Mar 2016 9:39pm
Romadog
Checkout ebay saw some yesterday on there.
Ebay no. 322053134013
Post #518887 29th Mar 2016 5:03pm
dasowak
Germany
Thank you Romadog! I've checked the offer, but it's out of my student budget
Overall after painting the sides costs approximately 1k€ Shocked for me - a bit to heavy I think.
Maybe I really have to accept the low-cost alternative Sad - remove the side windows of our defender and fit a painted plate over the hole. Neutral
Post #519085 29th Mar 2016 10:41pm
shaggydog
Thats what I did. If you get the top hat sections too can glue them on the inside and once covered with insulation nobody would ever know Thumbs Up
 Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #519199 30th Mar 2016 12:38pm
Romadog
Contact Tim at Marple Road Garage
http://www.marpleroadgarage.com/
or
Marc at Agricultural and Cross Country Vehicles
http://www.exmod.co.uk/
They work together.
They may have Blanking Panels that they have removed from Special Vehicles 110 CSW that were converted in early days for BT and AA etc.
http://gb.fotolibra.com/images/larger-thum...ation.jpeg
http://l7.alamy.com/zooms/180063d13f9a4dca...b6hf5c.jpg
http://www.ukemergency.co.uk/photo/dscd1007.jpg
They basically fit into the window hole rather than bodging a sheet of tin over the top. Son't need to create more holes. At least then they can be returned to windowed sides if in the future you want to change back.
Post #519257 30th Mar 2016 5:46pm
