Home > Td5 > TD5 110 - Utility Wagon Side Panels |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
Ah the utility side panels you mean. I've just managed to get my hands on a pair the proper ones are quite rare
28th Mar 2016 10:48am |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 999 |
Don't the 88" ones fit ?
28th Mar 2016 11:07am |
88 ones do fit but there's a vertical strip by the door frame and the internal strengthening rib is horizontal instead of vertical, so if you wanted to put mud stuff interior panels in it etc it's going to be a lot more work
28th Mar 2016 11:17am |
dasowak Member Since: 06 Mar 2016 Location: FFM Posts: 6 |
Wow - thanks for your quickly replies
Do the utility wagon side panels from a TD4 fit in a TD5 without doing a lot of adjustments? And is there any shop in the UK where I can order these panels? I've already searched in a lot of different forums and I can't find an answer. In German Forums the most members say that these panels are quite expensive and that I should remove the side windows from our defender, take a painted plate and stick it at the side. Best regards from German Paul |
28th Mar 2016 11:42am |
Yep puma ones will drop straight in. I've got a pair here that I'm waiting to paint when the weather improves. Took me 12 months of searching to find them.........
28th Mar 2016 11:51am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I have a set of a 1984 90. But I don't know if that will fit a 110. They will fit a 90 td5.
I think you are looking for 110 panels but that is not mentioned in your post. Where do you live in Germany? I will probably be in furstenau in may. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
28th Mar 2016 2:49pm |
90 panels are too long sadly.
28th Mar 2016 3:15pm |
Oh sorry... I'm looking for the TD5 110 side panels.
So if I understood you right the following panels are 88" side panels, because of the horizontal strengthening rib, aren't they? Click image to enlarge And is there maybe a Shop in UK where I can order the PUMA Utility Wagon side panels??? Thank you all for your amazing and quickly support! Best regards from Germany Paul |
28th Mar 2016 4:21pm |
Loz2286 Member Since: 31 Aug 2015 Location: High Wycombe Posts: 121 |
Dingocroft in High Wycombe may be able to source them. They are happy to sort shipping too.
www.dingocroft.co.uk 1999 Td5 110 CSW 1961 Series 2 88 LPG |
28th Mar 2016 9:39pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1747 |
Checkout ebay saw some yesterday on there.
Ebay no. 322053134013 |
29th Mar 2016 5:03pm |
Thank you Romadog! I've checked the offer, but it's out of my student budget
Overall after painting the sides costs approximately 1k€ for me - a bit to heavy I think. Maybe I really have to accept the low-cost alternative - remove the side windows of our defender and fit a painted plate over the hole. |
29th Mar 2016 10:41pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
Thats what I did. If you get the top hat sections too can glue them on the inside and once covered with insulation nobody would ever know Click image to enlarge Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
30th Mar 2016 12:38pm |
Contact Tim at Marple Road Garage
http://www.marpleroadgarage.com/ or Marc at Agricultural and Cross Country Vehicles http://www.exmod.co.uk/ They work together. They may have Blanking Panels that they have removed from Special Vehicles 110 CSW that were converted in early days for BT and AA etc. http://gb.fotolibra.com/images/larger-thum...ation.jpeg http://l7.alamy.com/zooms/180063d13f9a4dca...b6hf5c.jpg http://www.ukemergency.co.uk/photo/dscd1007.jpg They basically fit into the window hole rather than bodging a sheet of tin over the top. Son't need to create more holes. At least then they can be returned to windowed sides if in the future you want to change back. |
30th Mar 2016 5:46pm |
