Home > For Sale & Wanted > [For Sale] Sankey Trailer £395 |
Mach1 Member Since: 05 Nov 2012 Location: Norfolk Posts: 78 |
If it helps, I travel regularly between North Norfolk & London so happy to drop off anywhere in between (within reason) at no extra cost. 2013 90 HT
2015 110 DC 2012 FFRR 1996 Discovery |
22nd Feb 2016 3:03pm |
£395? 2013 90 HT
2015 110 DC 2012 FFRR 1996 Discovery Last edited by Mach1 on 18th Apr 2016 4:57pm. Edited 2 times in total |
25th Feb 2016 10:34pm |
Cheeky bump for the weekend..... 2013 90 HT
3rd Mar 2016 6:55pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7875 |
Oooh tempting... I'm not an expert but would I be right in thinking this isn't a 'wide track'? Is it mk1? Silly question i guess but any bad points?
3rd Mar 2016 11:42pm |
Morning, I'm probably less of an expert but I would say that it's a later MK1 because of the position of the jockey wheel. I'll check the measurements later but I assume that if it's a MK1 then it wouldn't be a wide track. Although I'm making these assumptions based on a bit of Internet research rather than any experience!
In terms of bad points, there honestly aren't any. Ive kept everything greased & working. It tows really nicely, very stable and easy to reverse for a short trailer. It's much sturdier than anything else that I've ever used. Unfortunately I don't have much use for it now so it's just taking space up on the drive which is why it has to go. 2013 90 HT 2015 110 DC 2012 FFRR 1996 Discovery |
4th Mar 2016 7:00am |
I've measured the trailer tonight & it is definitely the narrow track. 2013 90 HT
4th Mar 2016 11:23pm |
Price reduced to £395... 2013 90 HT
18th Apr 2016 4:56pm |
Hi, any photos of the tub empty, condition of underside and really like to see it on you Defender, if not too much trouble. Just want to see how it 'sits'.
I'm between London and Norfolk and still interested Thank you. James |
18th Apr 2016 6:59pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3696 |
Good luck with the sale,
Great price for an already smart looking sankey with a hitch. It should sit fine as long as you get a dixon drop plate, its deigned to go on the 4 bolts in the cross members but with the drop plate you can get it close. Although I'm tempted to get the wheel carrier to move it slightly up. Go on James |
18th Apr 2016 7:58pm |
James, no problem to do some photo's but I'm not going to be there for a couple of weeks. It all looks in good condition to me but I'm happy to PM you the address if you want to pop over & have a look, it's only sitting on my driveway.
It sits fine on both of my Defenders but as Stacey007 says, you would need the Dixon drop plate. I have the NATO hitch fitted & ready to go, all you would have to to would be to get the drop plate fitted. 2013 90 HT 2015 110 DC 2012 FFRR 1996 Discovery |
19th Apr 2016 11:03am |
PM sent
19th Apr 2016 11:14am |
jk84 Member Since: 17 Feb 2015 Location: Wherever my Defender takes me... Posts: 720 |
Has this sold in the end? MY15 Aintree 110 SW - for sale - https://www.defender2.net/forum/topic82781.html
MY16 Santorini 90 HT - sold |
16th Aug 2016 6:07pm |
I couldn't get authority from the financial controller
Mach1 still had it in May and had started using it again, so you might be lucky. I am still tempted but can't. James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
16th Aug 2016 8:54pm |
Go on.... Do it
Click image to enlarge I got the green light using the, they are getting rare now so not many left. It will always be worth what I paid I've enjoyed doing mine up also. Still bits left to do but really suits the Defender |
16th Aug 2016 9:21pm |
