Home > Td5 > Can I use Pre1986 brake pads on newer model? |
travis818 Member Since: 10 Feb 2016 Location: Singapore Posts: 2 |
Hi all,
I've ordered a set of defender front brake pads wrongly and received the STC2956 (for pre 1986 Defenders using STC8573 retaining pins and clips). I'm wondering if it fits my MY2001 ABS model which uses SFP000260 brake pads and STC8574 retaining pins. Apart from how the brake pads are being secured, do different MY calipers differ? |
10th Feb 2016 4:21am |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2876 |
Why woul you want to muck around with something your life depends on get correct parts
10th Feb 2016 8:48am |
Return the pads and get the correct ones 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
10th Feb 2016 9:04am |
Have already placed order for the correct set but wondering if they are both compatible just with a different pin to hold them down.
Unfortunately, air freight cost is more than the item cost so returning is not an option. |
10th Feb 2016 10:09am |
