Home > Technical > Converting 7pin to 13pin towing electrics |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6482 |
Not specifically Puma but covered a bit here:
http://www.defender2.net/forum/topic39094.html?highlight=ignition 1988 90 Td5 NAS soft top 2015 D90 XS SW |
18th Jan 2016 2:52pm |
NJS22 Member Since: 26 Oct 2012 Location: Cornwall Posts: 169 |
I just use an adaptor plug, you can get both 7 to 13 or 13 to 7, I think I got mine from a trailer or caravan accessory shop about £5. 1998 90 50th Anniversary 4.0 V8
2016 90 Adventure 2015 Range Rover Sport 1971 Range Rover 2 Door Wife won't let me have any more...!!! |
18th Jan 2016 2:58pm |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
The puma is a plug and play socket I believe so you simply need to purchase the 13 pin loom ??? Plugs in behind the offside rear arch
18th Jan 2016 3:22pm |
Plug and play except for the branch forwards for the ignition, as per my link above 1988 90 Td5 NAS soft top
2015 D90 XS SW |
18th Jan 2016 3:25pm |
shipbadger Member Since: 10 Jan 2016 Location: Royal Forest of Dean Posts: 19 |
I recently had a trailer custom built and to pass the type approval at the testing station it had to be fitted with a 13 pin plug. When I collected it I realised I have only 7 pin sockets on my vehicles. The guys who built it dived into the workshop and plugged an adapter into the plug, job done.
Tony Comber |
18th Jan 2016 4:53pm |
