Home > Technical > led indicators and hazard light not working |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19579 |
I'd start checking earths.
10th Jan 2016 6:52pm |
Forgot to add...
I'd especially check the main earth straps to chassis underneath. Remove them, clean and re-tighten. LED's are a lot more sensitive to poor earths and voltage drop by nature, a poor earth connection can cause all sorts of odd issues. |
10th Jan 2016 6:58pm |
Ranger Member Since: 17 Nov 2011 Location: United Kingdom Posts: 75 |
Had the same problem last week. Was the relay, moisture drips onto it and it'll work intermittently/partially, swap it for a known good one and check again.
10th Jan 2016 8:28pm |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
Thanks for your help guys. It was the relay. Got a new led variable do dah from the local indie landy place.
I broke the hazard switch opening it up to clean it as I'd been having problems with that too. New one on order and due in tomorrow. 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
11th Jan 2016 5:41pm |
