Home > Technical > Stranded, help please.
Page 2 of 2 <12
^^^ That one too, even if it's just a crack you can hardly see it could arc. Even more do if moisture levels are high.
Post #490688 10th Jan 2016 7:11pm
chris38
It was pretty wet on the way up here, snow and slush so pretty moist. Cheers
Chris
300tdi Defender 90
Post #490797 10th Jan 2016 10:55pm
scotsstag
Scotland 2004 Defender 90 Td5 CSW Rutland Red
If you're really struggling then luckily there is a great independent L.R specialist just a few miles down the A75 from you at Twynholm.
They are called W.B.GALLOWAY and their number is 01557-860240, ask to speak to Bill, he runs the place. Thumbs Up
Edit...
Forgot to mention they have a recovery truck as well just in case you needed recovered to the workshop. 04' 90 Td5 CSW..
Post #490811 10th Jan 2016 11:25pm
chris38
Thanks for that will give him a ring this morning Cheers
Chris
300tdi Defender 90
Post #490880 11th Jan 2016 9:36am
chris38
Update,
After getting it trailered back home got a friendly auto leccy to have a look.
Much melted insulation stripping later and full dash removal traced the short back to behind the heater box, two wires had shorted together and caused major damage to the loom further up.
It's now back up and running and I have the satisfaction of knowing that it's not going to burst into flames any time soon. Looking at the damage of the wires that were replaced looks like that could have been a possibility.
Thanks for your ideas and offers of help. Cheers
Chris
300tdi Defender 90
Post #494490 20th Jan 2016 7:31pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Good to hear, have you got photos of the burnt loom insitue ? Was there any indication what caused them to chaff, protruding bolt for example. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #494501 20th Jan 2016 7:54pm
chris38
No photos just bits all over the floor.
Leccy didnt see anything that had caused it to break down. Just wear and tear I guess. Cheers
Chris
300tdi Defender 90
Post #494716 21st Jan 2016 12:20pm
Page 2 of 2 <12
