Home > Td5 > TD5 Anti Stall
Page 2 of 2 <12
Laurie
Mine's fine. I never have to use the handbrake on hill starts.
Post #453316 8th Sep 2015 11:32am
excossack
I had to do a hill start the other week on a steep hill with a trailer on the back. Despite getting the biting point and what I thought was enough revs I kept stalling. In the end I had losts of revs and wheel spinning just to get going!
Now I need a steep hill again to try the anti-stall feature and see how I go. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #453325 8th Sep 2015 12:03pm
JWL
With a Td5 it is quite an art, the trick is to let the clutch pedal out completely before throttle. When I had a test drive in a Puma it took me a couple of attempts before I got it right and then when I got back into my own Td5 to drive home I stalled it getting out of the Experience carpark, that's embarrassing Whistle
Post #453368 8th Sep 2015 2:56pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
so is it the same as putting in first gear, feet off all peddles and let it trundle along?
Post #453390 8th Sep 2015 5:07pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
Yes don't touch the clutch pedal or the throttle. The td5 is really capable in low first as long as it is a little smooth if it falls in a ditch with both front wheels it still probably stalles but if it is a steep hill you will be amazed how much it does. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #453413 8th Sep 2015 6:32pm
Page 2 of 2 <12
