Home > Td5 > TD5 Anti Stall |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Mine's fine. I never have to use the handbrake on hill starts.
8th Sep 2015 11:32am |
With a Td5 it is quite an art, the trick is to let the clutch pedal out completely before throttle. When I had a test drive in a Puma it took me a couple of attempts before I got it right and then when I got back into my own Td5 to drive home I stalled it getting out of the Experience carpark, that's embarrassing
8th Sep 2015 2:56pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
so is it the same as putting in first gear, feet off all peddles and let it trundle along?
8th Sep 2015 5:07pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Yes don't touch the clutch pedal or the throttle. The td5 is really capable in low first as long as it is a little smooth if it falls in a ditch with both front wheels it still probably stalles but if it is a steep hill you will be amazed how much it does. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
8th Sep 2015 6:32pm |
