Home > Td5 > Buying help needed TD5 Defender.
Rommel
Hi All.
I am in the process of buying my 1st TD5 Defender after previously owning a number of 300 TDis Can anyone tell me what year and or Reg the 15P engine came in also what time did the VIN number 2A622424 start?
Thanks.
Tony.
Post #450030 28th Aug 2015 12:09pm
bob neville
Late 2001 with the face lift dash ?
Mine is September 2001 and has the 15P fitted.
My chassis number starts 625....
2013 Defender 90 CSW - sold
Post #450032 28th Aug 2015 12:16pm
Johnnyboxer
Is that engine better?
Post #450051 28th Aug 2015 1:31pm
rallysteve
2A chassis number is 2002, 3A 2003 and so on.
As far as i know all facelift defenders (dash centre console) have the 15p engine. Easy to identify by the EGR cooler on the front of the cylinder head though.
Post #450054 28th Aug 2015 1:40pm
Rommel
This is what I read up on it.
Cylinder heads crack around the injectors on vehicles with engine number prefix 10P. A symptom is diesel in the sump; the oil level rises and the dipstick smells dieselly. The engine might run-on after switching off, which can be very serious. Engines with a number starting 15P don’t have problems, and vehicles with ’52 registrations or newer will be ok. Check the paperwork to see if early vehicles have been rectified.
The heads were originally positioned with plastic dowels, which meant the casting could move fractionally. This could disturb the head gasket seal, resulting in coolant loss and overheating. Steel dowels were used from VIN 2A622424. Check the service paperwork to see if earlier engines have been fixed.
A bolt retaining the oil pump sprocket can come loose – sprocket comes off, no oil, goodbye engine. Bolts should have been fitted with a thread-locking compound but often weren’t. If the job hasn’t been done, do it as preventive maintenance.
However how true this is, is a matter of conjecture as I have heard of later engines blowing head gaskets!!!
Thanks for the replies.
Tony.
Post #450056 28th Aug 2015 1:46pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
I have seen several of the plastic dowels that have come off the 10P engines and they have a serious bend. However when the head is replaced, the recommendation is to not use the steel dowel, any ideas why?
Post #450143 28th Aug 2015 6:22pm
HossBog
Re: Buying help needed TD5 Defender.
Rommel wrote:
Hi All.
Thanks.
Tony.
Mine was registered on 20th Sept 01, is chassis 623xxx and has the 15p engine. So I'd assume any '51' plate or newer.. 2002MY Defender 90 H/T
Post #451224 1st Sep 2015 10:19pm
110MGD
2001 Defender 90 Td5 CSW Epsom Green
Steve
If they have this does that mean it's a later engine?? 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel.
2016 E220 CDI Night Edition Estate
2014 VW UP!
2x D3 and 1x D4 GONE
Post #451380 2nd Sep 2015 1:19pm
Martin
Site Admin
2002 model year onwards are 15P engines. Also new dash, new one piece rear door.
1999, 2000, 2001 model years are 10P
Remember is it MODEL year, not build year. The chassis number tells you the model year, not the 6 numbers at the end but the character at the start of the last 8 characters.
e.g.
SALLD.......1A523411 would be 2001 model year (10P)
SALLD.......2A625451 would be 2002 model year (15P)
SALLD.......3A744788 would be 2003 model year (15P)
(I have made up all the last 6 numbers BTW)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #451391 2nd Sep 2015 1:49pm
Freypal
United Kingdom 1992 Defender 90 200 Tdi HT Portofino Red
Had the 10p in my td5 disco 2. Brought it on 120k miles, sold it on 190k miles. No engine issues whatsoever.
Post #451414 2nd Sep 2015 2:42pm
ozzy57
2002 Defender 110 Td5 CSW Alveston Red
Rommel wrote:
Hi All.
Thanks.
Tony.
Just seen your location, if you want a second opinion on a vehicle, I'll happily give it a look over with you. It wasn't me!
Post #452601 5th Sep 2015 9:50pm
SailingTom
Steve
Mines a 51 plate td5 with the centre dash from new but is the 10p engine. It was a strange old spec of left overs though so your probably right in general
Post #452882 6th Sep 2015 8:33pm
