Home > Technical > Rear Door Stuck Shut - Help ! |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10361 |
push the button lock on the inside up and down, it will eventually unlock......it's a feature.
7th Aug 2015 7:19pm |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2260 |
Same problem on mine .....have you tried pushing the door inwards keeping the pressure on then unlock it ....it worked for me!.......the mechanism is a little tight .....it loosened itself at about 1000 miles..... |
7th Aug 2015 7:29pm |
saltydog Member Since: 13 Mar 2012 Location: Aberdeenshire Posts: 91 |
There is no more travel inwards, it seems to be as if it is jammed solid, IE too tight ! LR Defender 110 XS Utility Wagon
LR Discovery 2.0 Sport HSE LR Discovery 4 Landmark |
7th Aug 2015 7:34pm |
try it the other way pushing from the inside and then try the lock from the inside ot get someone else to use the key and handle from outside .............try holding the outside handle pressing upwards and try the fob to open ........if this does not work i would take it to the dealet...good luck!
7th Aug 2015 7:45pm |
Thank you GREENI did what you said and bingo after twenty times up and down I got it open ! LR Defender 110 XS Utility Wagon
7th Aug 2015 7:56pm |
Only 20???
7th Aug 2015 8:34pm |
Question is why ????? LR Defender 110 XS Utility Wagon
7th Aug 2015 10:17pm |
Froogle-Yorkshireman Member Since: 10 Jul 2010 Location: Yorkshire Posts: 349 |
Because it's a Defender and maticuously hand built Proud owner 110 Utility XS
Ex RR Sport HST V8 Ex Td5 90 |
7th Aug 2015 10:55pm |
