Home > Technical > Rear Door Stuck Shut - Help !
saltydog
2015 Defender 110 Puma 2.2 USW Corris Grey
The rear passenders door on my 110 UW has stuck shut. The central locking does not open the lock, inside and outside handles dont open it either. Any suggestions. Only 200 miles on the clock - typlical ! LR Defender 110 XS Utility Wagon
LR Discovery 2.0 Sport HSE
LR Discovery 4 Landmark
Post #444077 7th Aug 2015 7:17pm
push the button lock on the inside up and down, it will eventually unlock......it's a feature.
Post #444079 7th Aug 2015 7:19pm
nitram17
Re: Rear Door Stuck Shut - Help !
Same problem on mine .....have you tried pushing the door inwards keeping the pressure on then unlock it ....it worked for me!.......the mechanism is a little tight .....it loosened itself at about 1000 miles.....
Post #444087 7th Aug 2015 7:29pm
saltydog
There is no more travel inwards, it seems to be as if it is jammed solid, IE too tight ! LR Defender 110 XS Utility Wagon
Post #444091 7th Aug 2015 7:34pm
nitram17
try it the other way pushing from the inside and then try the lock from the inside ot get someone else to use the key and handle from outside .............try holding the outside handle pressing upwards and try the fob to open ........if this does not work i would take it to the dealet...good luck!
Post #444094 7th Aug 2015 7:45pm
saltydog
It worked !
Thank you GREENI did what you said and bingo after twenty times up and down I got it open ! LR Defender 110 XS Utility Wagon
Post #444095 7th Aug 2015 7:56pm
Only 20??? Laughing Laughing Laughing
Post #444107 7th Aug 2015 8:34pm
saltydog
Question is why ????? LR Defender 110 XS Utility Wagon
Post #444148 7th Aug 2015 10:17pm
Froogle-Yorkshireman
2010 Defender 110 Puma 2.4 USW Stornoway Grey
Because it's a Defender and maticuously hand built Rolling with laughter Proud owner 110 Utility XS
Ex RR Sport HST V8
Ex Td5 90
Post #444165 7th Aug 2015 10:55pm
