Home > Maintenance & Modifications > Headlight cleaning system |
Looks promising for clearing LED headlamps which do not really warm up from snow in the winter.
From the German language website it looks like the item is commercially available already and ready to be installed. Guess the English translation has not been updated yet. Wonder if it also works for a SVX front, need to check. Eric http://www.entreq.de/media/uploads/20150203_130100.mp4 You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
30th Jul 2015 5:36am |
That's just the radiator that's sprung a leak Ray
30th Jul 2015 9:47am |
could you post the link? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
30th Jul 2015 12:48pm |
Daniele,
Go to Entreq website. Click on: - Werkstatt - Beleuchtung und Scheinwerferreinigung - Scheinwerferreinigungsanlage Land Rover Defender The price is €589 including VAT and installation at their workshop. You can not just order the item for installing it yourself. I should be at Entreq again later this summer for another SVX job, so hope to see the item then. Best, Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
30th Jul 2015 3:05pm |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1709 |
Headlight washers I'd say are just a waste of water and dont even work on cars designed for them effectively.
Would be the last thing i'd want to fit, although was tempted to get a genuine land rover defender kit for one of my others, but only because it was unusual. |
30th Jul 2015 3:23pm |
Agree they don't do much for cleaning, but was thinking more about removal of accumulating snow from LED headlights which do not heat up enough to melt it. From what I see in the movie, that would likely work. This snow accumulation on LED headlamps has been well reported on here. Now...., I do not drive in the snow.... You never actually own a Defender. You merely look after it for the next generation.
30th Jul 2015 4:10pm |
Hotshot and standard washer jet would do it ok for melting snow etc
30th Jul 2015 8:08pm |
Agree at 100%.
Hotshot should be the best solution for de-icing the LED headlamp...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
30th Jul 2015 9:33pm |
I also think that the installation on the SVX could be a problem due to the shape of the headlamp surround
30th Jul 2015 9:43pm |
Plenty of washer jet styles to choose from
External washer pump and a hotshot , should be fairly easy to do jet like this maybe eBay Item No. 261651424159 |
30th Jul 2015 9:58pm |
