![]() | Home > In Car Electronics > Focal Speaker Upgrade |
I upgraded all my speakers, as well as a sub with Focal kit, which is of really high quality. I got them from Kevin at MUD about 6 months ago after he said he was able to source them.
He's now listing them on his site, he is able to get ANY Focal items, so if you don't see it on his site, give him a call. The quality is amazing and my 'system' puts the local 'boy racers' to shame ![]() Definitely recommended. http://www.mudstuff.co.uk/what-s-new.html |
Thanks Steve .. On my list since fitting focal i20
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
A item that has been on the "to do sometime/maybe list"
Presume these for the std regalement of the fronts http://www.mudstuff.co.uk/focal-isn100-speaker.html California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Perfect your standard grills work from the OEM ones
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 ![]() ![]() ![]() |
Ditto to that, have just fitted the same Focals into my 90 and although they are better, more bass is needed. I may well end up amplifying the Focals but defo need a sub as well.
Oh course bass is required all your doing with the 4/5 inch is releasing the mid n highs
As Ken said, you won't get bass from standard speaker sized replacements.
In an ideal world, you need an amp that runs a sub and get crossovers to separate the mid from the highs and run tweeters on the dash and use the standard speaker holes to run Focal mid or mid/highs. I unplugged my standard speakers and put 2 6x9's in separate enclosures, used for mid range. An iPhone has enough 'equalizer' settings in the music menu to find the ideal sound you prefer. With it cranked up, it rattles your nose (as a passenger told me!). Though I never have it 'that' loud, it's just nice to have quality audio over the 'defender noise'. |
scotiach Member Since: 19 Nov 2014 Location: 5603 Posts: 36 ![]() ![]() ![]() |
I just installed speakers front and rear and this little Pioneer active sub on the back of the cubby: http://www.pioneer.eu/eur/products/25/131/201/TS-WX120A/page.html
Plenty of bass (up to max 125 Hz) - ideal if your speakers can go that low to 'meet' the sub's upper limit. 4" speakers are going to struggle to do that though, mine are high-passed at 200 hz and the 6.5"s in the rear cover the gap. At these frequencies it doesn't really matter where the speakers are, if you can adjust the timing of the signal from your head unit. |
