Home > Td5 > Alternator head light loom feed |
yes can come from alt or bat ,the biggest terminal on alt is easy way to describe it
21st Mar 2015 8:44pm |
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 430 |
Yeah just uploaded photos
21st Mar 2015 10:08pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
I took mine direct from the battery ran the live ( sheathed) along the n/s chassis rail cable tied to the main live feed. 2005 Td5 90 XS
Steve |
21st Mar 2015 10:20pm |
The alternator is closer and seems an easier option ?
21st Mar 2015 10:50pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5743 |
Is the starter motor an option? 1999 Defender TD5 110
21st Mar 2015 11:07pm |
Personally i would run back to battery as i would preter a connection with no vibration
running to battery also mean you can get a fuse closer to connection |
The alternator is pumping out 14.3 volts is that too much for the lights ?
23rd Mar 2015 11:07pm |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 999 |
The landrizeiger kits recommend using the alternator - that's good enough for me.
What I want to work out is the neatest way to run from there to the back of the light, where to mount the relays, and then the beat route for the loom to pass across to the other wing. |
23rd Mar 2015 11:12pm |
No thats normal voltage
its the voltage drop due to weak wiring you want to get rid off |
23rd Mar 2015 11:13pm |
Thanks.
Where can I get relay mounts, the kit didn't come with them Tank |
24th Mar 2015 9:18am |
Someone must know where I can get relay mounts ?
24th Mar 2015 1:15pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16880 |
Virtually all car accessory shops (inc Halfords) sell them, as do all the online retailers such as Vehicle Wiring Products.
See here Not at all hard to find! |
24th Mar 2015 1:30pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5084 |
They seem to be unbelievably rare if you mean the metal tag holder that allows the relay to clip to them and then you can screw or bolt them to a panel. If you mean the female holders that the relay slots into they are everywhere as the above post says, but not the little plastic or metal tag clips that allows you to fix the relay somewhere. I have been looking for some for ages and cannot locate them anywhere. The only supplier I was able to find was in China and you had to order five thousand. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
http://www.youtube.com/user/conwy1 |
24th Mar 2015 1:33pm |
Hi Blackwolf
Its the clips that allow you to fix them somewhere on the body work, like a little metal L bracket. I cant find them but will look on the website you provided. Halfords couldn't help ? Cheers Tank |
24th Mar 2015 5:22pm |
