Home > Maintenance & Modifications > 7 pin to 13 pin conversion |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5084 |
Unless you also have a 12S socket fitted as well as a 12N it is quite an involved job. Yes you can rewire a 12N easily enough into the terminals in a 13 pin socket. However there is no live feed for battery charging from a 12N socket, so you would need to wire one into the 13 pin you will also have to install a relay and have it switched from the live side of the ignition. If you do have a 12S fitted then the wire from terminal 2 is the ignition positive feed for battery charging.
If you do have both sockets fitted then it is just a matter of fitting the wires to the relevant terminals of the 13 pin although they are very close together. 13 pin Plug Click image to enlarge 13 Pin Socket For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
6th Mar 2015 4:13pm |
Busboy Member Since: 23 Jan 2012 Location: West London Posts: 182 |
I may have answered my own question , just been underneath the wagon and about 2 foot along the loom from the socket end is a grey plug connection. There seems more wires in the other sides connector than on the tow socket side. So hopefully it is plug and play. Steve
6th Mar 2015 4:25pm |
Usually 12N sockets are wired with cable in a black sheath and 12S are wired with cable in a light grey sheath
Although new 13 pin multi core cable is also sheathed in black. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 Last edited by gilarion on 6th Mar 2015 4:31pm. Edited 1 time in total |
6th Mar 2015 4:27pm |
Hi gilarion
Thanks for your reply, I've only got the one socket with a black cap if it makes a difference. Steve |
6th Mar 2015 4:31pm |
If you have a grey socket connection which will be for a 12S socket then it looks like all you will have to do is feed the core cables from that connection block to the new 13 pin socket following the wiring diagrams given. If you have to join the cables with a new length of wire make sure you use good quality connectors and not those awful scotch block things. It may be possible to buy the socket feed with the right connector to connect to the connector you have that would make it so much easier. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
6th Mar 2015 4:39pm |
What year model is your 110 as there are wiring kits available from Land Rover for wiring a 13 pin and also a 12s but their part numbers differ depending what model and year. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
6th Mar 2015 4:48pm |
Yeah it's on an 11 plate gilarion. Steve
6th Mar 2015 4:54pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16895 |
The 12N socket is plug and play and is what you describe.
The 12S wiring is not fitted as standard but is what you need to do what you want. It is reasonably involved to add the 12S wiring and involves wiring back to the battery box and taking an "ignition on" signal from inside the dash. If you had both 12N and 12S, you could very easily fit a fully-wired 13 pin socket. With just the 12N, you could easily fit a partially wired 13 pin socket which would be fine for towing a trailer, but not for what you want. |
6th Mar 2015 5:06pm |
Blackwolf
thanks me being a clueless git I hope I can plug and play, just need to know the best place to get the kit... obviously OEM would be great but with the LR price tag there must be a good alternative. Steve |
6th Mar 2015 5:36pm |
OEM 13pin wiring harness LR005919 Price £110.40 inc VAT
http://www.paddockspares.com/lr005919-kit-tow-bar-electrics.html For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
6th Mar 2015 6:08pm |
cheers boss Steve
6th Mar 2015 6:58pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 488 |
The kit can be bought from MPS Trading on eBay, for £99.99 incl. delivery -
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...1023475683 Click image to enlarge . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
6th Mar 2015 8:08pm |
Cheers Paul...... Steve
6th Mar 2015 8:30pm |
I've brought the 13 pin kit now,so my question is is it easy to fit? I already have the 7 pin system fitted on an year 11 plate.
An idiots guide would be very helpful Steve |
28th Mar 2015 8:16am |
