Home > Technical > anti roll bar question |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1728 |
Not done it but massive understeer would result I would imagine - through the hedge forwards!
24th Feb 2015 9:19am |
NickH Member Since: 02 Nov 2014 Location: Halifax Posts: 204 |
You can fit just the front one without any ill effects.
The rear one doesnt do a massive amount anyway as you can probably tell by its thickness (very thin). Early Classic RRs (basically the same suspension) used to have aftermarket kits available, one kit just had a huge thick rear arb, no front one, and the other make had a huge thick front arb and no rear one. Crash on 2003 Td5 90 2013 sport hse 2012 700 raptor quad 2012 siromer 4x4 tractor |
24th Feb 2015 3:33pm |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 667 |
I fitted a front ARB to my 110DC it made quite a difference
I then went on to fit a X-ENG rear ARB ..... |
24th Feb 2015 5:02pm |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
I've running only front ARB, it corners incredibility well at speed - no serious under steer issues except on wet roundabouts.
Just aim for the exit after the exit you want, and you'll be good. @eddie What difference did fitting a rear bar make? |
24th Feb 2015 11:59pm |
@mrd1990
It stiffened the rear up quite a bit, mind you the X-Eng bar is very thick, but results in very flat cornering in my 110DC There is another ARB thread somewhere with pictures of mine freshly installed... Other thread here http://www.defender2.net/forum/topic12583.htm |
25th Feb 2015 12:23pm |
dioliahary Member Since: 18 Jan 2015 Location: Manchester Posts: 668 |
Thanks, hope the crash and exit quips are tongue in cheek
If its safe to do so I think I will give it a go, so far so good |
25th Feb 2015 10:23pm |
