Home > Puma (Tdci) > Adding Oil in diesel and why? |
the amount of 2so you put in is not enough to show as red in the diesel , i thought that it might , so added some 2so drove it so mixed in then dipped some out , and you couldnt see that it looked red at all , cant remember what make it was but course some 2so might be a stronger red colour or just use green 2so As far as i know if you get dipped and it looks suspect then a sample is taken for checking , as no tax offence has taken place i would say there couldnt be anything customs and excise could fine you for Anyone know different ? as for using 2so in dpf eqquipped vehicle i dont know , but some do |
24th Feb 2015 8:51pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3618 |
My BM has a DPF no problems so far but I do use the Castrol 2SO that is high in detergent and low smoke/soot DEFENDER 90 TDCI XS,
24th Feb 2015 9:32pm |
2so seems to cut down the black smoke , so should be better for dpf ????
dont know , never tried in dpf , so cant say either way ! any one noticed they get less smoke ? |
24th Feb 2015 9:36pm |
as posted before at the last MOT the tester could not believe how low my BMs emissions were, he thought his kit was u/s and tested it on another vehicle to be sure it was working. I do also change the oil every 8k and give it a good run up the motorway every now and again but it is mostly driven around town. Im convinced 2S0 (good stuff at low quantities) does no harm but does lubricate the whole fuel system and makes diesels smoother DEFENDER 90 TDCI XS,
24th Feb 2015 9:42pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1878 |
A lot on the disco3 site use 2so and they all seem to agree it makes the engine much quiter,
Might give it a go for a few tanks 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
24th Feb 2015 9:54pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1732 |
You do also get an occasional Castrol R smell which for those of us old enough to remember must be a good thing!
24th Feb 2015 10:37pm |
Dora Member Since: 12 May 2015 Location: South East Posts: 170 |
I was considering the adding of 2so to my 2.4 puma until I came across this article, don't think i'll bother now
http://www.fuelexpert.co.za/2-stroke-oil-i...-study.php |
13th Jun 2015 6:32pm |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 |
I've got to say that......I tried the 2SO and even after wanting to find a difference couldn't. So I recently started using BP Ultimate, and, definitely improved running, more responsive and less cold smoke when starting. I wouldn't say that the mileage gain is worth the additional cost but it has improved. I don't think I'm fooling myself because the inside of the exhaust tail pipe is more like a vehicle with a DPF with greatly reduced soot. I started with nothing and still have most of it left!
13th Jun 2015 9:10pm |
Last person i heard try it was towing a caravan with a old high mileage mondeo and was sick of black crap up the front of his caravan after towing , tried the 2so and was over the moon with the result and said no black crap up his caravan
13th Jun 2015 9:19pm |
