Home > Technical > Ignition Relay |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6037 |
Should be down behind the gearstick in with the fuses... there's usually 4 or 5 relays along the bottom.
unscrew the fusebox lid with the two large thumbscrews. |
12th Jan 2015 3:56pm |
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 |
Cheers jim, you wouldn't know which one it is would you Graham
1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
12th Jan 2015 4:18pm |
Isn't that mentioned on the inside off the lid? Roel
12th Jan 2015 4:20pm |
are right ok Graham
12th Jan 2015 4:23pm |
Son is going to see if he can buy one from work if not check it and see if he can do anything before he comes home tonight Graham
12th Jan 2015 5:11pm |
The lid ( my lid ) anyway doesn't tell you anything as the sticker thingy is missing, we have removed the metal cover and found the relays but not sure which relay is for the ignition as they all click when the ignition is turned on. any ideas as this switching off problem is driving us nuts Graham 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
19th Jan 2015 7:07pm |
can you feel them click when switching things on and off , might be lucky and find it that way
19th Jan 2015 7:17pm |
Will have another look at the weekend and let you know Graham
20th Jan 2015 1:17am |
