Home > Maintenance & Modifications > Anyone done a cat back system on 2.2 Puma |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19579 |
You can go completely straight through if you wanted but of course now you need the CAT present.
Alive do a CAT back system I think, you can get sooprts cats too but they are seriously pricey. |
22nd Dec 2014 6:38pm |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2163 |
I'm confused there is no cat on the 2.2 , only the DPF . Iv taken off the stupidly heavy no use for anything mid box AND the end small box . It's a major job taking off the DPF at the engine but what's the point ? It's only gona fail it's MOT
I have a slightly better performance with both boxes off and won't be touching the DPF . |
22nd Dec 2014 6:47pm |
So it's DPF instead of a CAT then?
22nd Dec 2014 6:55pm |
Custom
Yeh mate probs the same thing but the cats were all easyily taken off midway along the exhaust . There's no way your gona get through emotions with straight through on the 2.2 . Even if taken off its then gonna haf to go to BAS to have the ECU jiggered about wi . A big hastle when you could be better to have it have BAS wave his majic wand on it easy . |
22nd Dec 2014 7:03pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3755 |
IMHO, mucking around with the exhaust system on a Puma is not going to provide much, if any power gain.
However, I'd be interested to see a before & after dyno figure, stock exhaust against cat / middle muffler removed? Pickles. |
22nd Dec 2014 10:08pm |
