Home > Maintenance & Modifications > Anyone done a cat back system on 2.2 Puma
Defender-Stu
Hi Guys,
Has anyone done/fitted a Cat back system on a 2.2 Puma yeat as wanting to know if you get a nice sound difference and any power gains but at the same time does not mess the engine up etc?
Stu
Post #381034 22nd Dec 2014 5:54pm
You can go completely straight through if you wanted but of course now you need the CAT present.
Alive do a CAT back system I think, you can get sooprts cats too but they are seriously pricey.
Post #381060 22nd Dec 2014 6:38pm
keith
I'm confused Shocked there is no cat on the 2.2 , only the DPF . Iv taken off the stupidly heavy no use for anything mid box AND the end small box . It's a major job taking off the DPF at the engine but what's the point ? It's only gona fail it's MOT
I have a slightly better performance with both boxes off and won't be touching the DPF .
Post #381062 22nd Dec 2014 6:47pm
So it's DPF instead of a CAT then?
Post #381064 22nd Dec 2014 6:55pm
keith
Custom
Yeh mate probs the same thing but the cats were all easyily taken off midway along the exhaust . There's no way your gona get through emotions with straight through on the 2.2 . Even if taken off its then gonna haf to go to BAS to have the ECU jiggered about wi . A big hastle when you could be better to have it have BAS wave his majic wand on it easy .
Post #381066 22nd Dec 2014 7:03pm
Pickles
IMHO, mucking around with the exhaust system on a Puma is not going to provide much, if any power gain.
However, I'd be interested to see a before & after dyno figure, stock exhaust against cat / middle muffler removed?
Pickles.
Post #381138 22nd Dec 2014 10:08pm
