Home > Maintenance & Modifications > No main beam
Page 2 of 2 <12
munch90
Think you got it bit wrong
position 2 with key sidelights + dip beam not dim dip
dim dip was never really law , just a thing we done that europe fined ( or tried to ) us for doing
dim dip was never part of mot
Normally the resisters burn out which makes you just lose the dim dip
but not sure about the bit of postion 1 on the switch giving sides and heads with ign on ( after fitting relays and leaving dim dip resister connected ) for mot as normally on test you would switch sides on check , switch heads check , if they both come on together and no sides on alone if that should be a fail
Post #376486 4th Dec 2014 10:57pm
Cheshire Dave
If changing the headlight switch is easy, can someone give me an idiots guide to doing it please. I can find any reference in the Haynes book for fitting a new one.
Dave
Post #376491 4th Dec 2014 11:01pm
mk1collector
Unscrew the column cowls and remove then unplug the switch. Unscrew the nut holding the switch to the column (I think it's about a 13/14mm) pull switch out and then do the reverse to put it back together.
Post #376505 5th Dec 2014 12:09am
Cheshire Dave
Thanks MK1 and all
Post #376604 5th Dec 2014 1:59pm
Cheshire Dave
Rang Landranger Deeside 4x4 regarding fitting a new switch Saturday morning , no problem they said come along and I'll fit it for you. Switch fitted in no time, what excellent service, can't recomend them enough! If you need parts and help they are top class !!!
Dave
Post #376931 6th Dec 2014 11:24pm
mk1collector
Did it fix the problem?
Post #376948 7th Dec 2014 1:06am
Cheshire Dave
Yes I'm glad to say, I can see we're I'm driving now, spoils all the fun!
Post #376990 7th Dec 2014 11:06am
munch90
that's good then
Post #376991 7th Dec 2014 11:09am
Cheshire Dave
While i was there someone else came in with the same problem, all lighting went !and he'd just been pulled by the police fortunately he was only a mile from home and they let him off.
Post #376994 7th Dec 2014 11:26am
Page 2 of 2 <12
